Stalling after cam install
Old Mar 2, 2011 | 11:33 AM
rogerdoger1993's Avatar
Default Stalling after cam install
Hey guys I am just looking for a little advice here. I just put in a cc503 cam, 1.6 rr, long tube headers, cat delete, egr/air delete. And the car seems to idle just fine. However, when I go WOT and back off the car will stall out. Could the stock injectors and stock tune be causing my problems? BTW it is a 93 corvette LT1.
Old Mar 2, 2011 | 11:43 AM
myltwon's Avatar
stock tune is likely your problem.
stock injectors shouldn't be a problem, atleast not with 24# ones not sure on the 22# injectors
Old Mar 2, 2011 | 11:44 AM
MEAN LT1's Avatar
Sounds like an easy fix. If you have TunerCat I would adjust the Throttle follower IAC offset vs MPH.
Old Mar 2, 2011 | 11:47 AM
I am not sure what that means. Should I just buy a tune from PCMforLess to fix the problem?
Old Mar 2, 2011 | 11:48 AM
BTW my car is speed density.
Old Mar 2, 2011 | 11:52 AM
iWon's Avatar
You for sure need a tune... you think your factory tune is working for that setup? Contact LT1PCMTUNING or PCMFORLESS ect ect they'll get you hooked up.
Old Mar 2, 2011 | 11:57 AM
ok i just sent a message to solomom at lt1pcmtuning
