Suggestions?
Old Mar 4, 2011 | 11:10 AM
Z28Camaro30Ann's Avatar
If you don't like Advanced Induction, you can go to Lloyd Elliott as well. He did my heads and the price is not bad at all! DEFINATELY worth the money!
Old Mar 4, 2011 | 12:09 PM
idformula's Avatar
I would take a look at the lifters before I tore it down, but if your looking for an excuse to build a motor, then go ahead. It sounds like you have a fairly well thought out build, AI and LE both make great power, so that's your choice. I would do a spec'd cam by either one myself, much better choice than an off the shelf cam. I would check the casting numbers to make sure their lt4's.
Old Mar 4, 2011 | 12:21 PM
ShroomTat4yaHed's Avatar
Well now I got a money issue. If it ain't one thing it's another. You think I could just run forged rods and pistons with a stock crank lt4 top end upgraded springs and pushrods? Same hotcam as well. As a n02 setup.
Old Mar 4, 2011 | 12:37 PM
ss.slp.ls1's Avatar
Hmmm, I think someone already suggested that...oh yeah, it was me.
Yes you can do that. Forged rods and pistons with the stock crank will make for a very stout 355 that can take a lot of power and a good amount of rpm. the LT4 top end will make for a mild street set up off the nitrous and with a healthy 200 shot you'd beat pretty much anything on the street.
Then later on down the road when you have more money, you can port the heads and get a custom grind cam.
Old Mar 4, 2011 | 12:40 PM
Yeah. I remember you suggesting that, i thought to have the 355 though you had to bore? Something I don't feel like doing currently.
Old Mar 4, 2011 | 12:45 PM
speedracer2536's Avatar
Boring is not that expensive.. It should be done to bring a new cylinder surface up anyway..
Old Mar 4, 2011 | 12:49 PM
If you are gonna do new pistons, you NEED to bore IMO. Otherwise any problems that block has is just going to be a weak point later if there is any wear, burrs, or other damage...
What you need to do to ensure proper fit of the cylinder is get your pistons with a slight overbore, take them with your block to a shop and tell them you want the block bored to fit those specific pistons. That way you are SURE the pistons fit properly and you KNOW nothing is wrong.
If you just get a stock sized piston and make it work, you are playing with fire IMO.
Old Mar 5, 2011 | 09:02 PM
slomaro94's Avatar
this is unrelated and you may not know since you bought the car the way it is but do you know what kind of valve covers are on the car, i need a set and cant find a set with the notch for the alternator. i seen in the pic that they are polished
Old Mar 7, 2011 | 11:43 AM
I'm at work right now. I'll check when on break. I beleive they are cannon or something like that? i'll let you know.
Old Mar 7, 2011 | 11:47 AM
I'm sorry. They're Canton aluminum valve covers. 205$ on Summit Racing. They've got a massive ammount of clearance btw.
