Leaking Canton oil pan
I just keep wiping down everything But its getting really old. Im usuaing a stock felpro replacement oil pan gasket. Everythings snuged up decent but not to tight.
What have people done to remedy this? Do I just need to sell this and get a different pan? Im getting so upset with the leak, and a minor timing cover leak that I think Im going to pull the motor and just reseal it again even though there's not even 10k miles on it.
You could also coat it in hylomar. That's what im gonna do
Gregbob I did use the permadry, and just the permadry gasket, only spots with rtv is the cracks between the timing cover and block and rear main housing and block.
Although I did not crank down on them fearing I would push the gasket out.
