95 cam into a 94?
Old Mar 7, 2011 | 02:00 PM
355z28's Avatar
Default 95 cam into a 94?
I cant remember the difference. I know the 95 Is a vented opti, and the 94 is non vented. I know the 94 opti is ran off the center of the timing gear, and the 95+ is off of the dowel.
Can I just cut my dowel or tap it in, and run the 94 timing set to make it work?
Thanks
Austin
Old Mar 7, 2011 | 03:05 PM
ss.slp.ls1's Avatar
Try tapping it in first, then grind what you can't tap in to get to the required length, I believe it is .340".
Old Mar 7, 2011 | 10:03 PM
whytryz28's Avatar
Cut it, thats what I did, took 3 seconds.
