vanishing coolant
Old Mar 12, 2011 | 05:02 PM
93z28ltone's Avatar
Something is leaking back didn't smell like coolant
Old Mar 12, 2011 | 05:24 PM
93z28ltone's Avatar
So set out here and check and double check for about 30 min the pressure Gage only dropped 1 psi so any other suggestions
Old Mar 12, 2011 | 10:10 PM
SS RRR's Avatar
Village Troll
At what pressure?
Old Mar 13, 2011 | 12:40 AM
93z28ltone's Avatar
18psi
Old Mar 13, 2011 | 03:18 AM
snk-huntr's Avatar
had the same problem and it was a head gasket ,, pressure test it
Old Mar 13, 2011 | 03:36 AM
93z28ltone's Avatar
ok i did the coolant system pressure test with the tool i rented from autozone what else can i do to check to see if i have head gasket leak
Old Mar 13, 2011 | 10:02 AM
Cheap Guy's Avatar
You can also get a coolant test. Cost about $30 and it will also tell you if you have a blown head gasket.
Old Mar 13, 2011 | 11:22 AM
93z28ltone's Avatar
You can buy that autozone right
Old Mar 13, 2011 | 12:42 PM
Cheap Guy's Avatar
I wasted a lot of time screwing around trying to find out why it was overheating and where the coolant was going. I just got so frustrated when I had the same situation and I just took it to a mechanic. He did the test and sure enough, blown head gasket.
Old Mar 13, 2011 | 05:55 PM
SS RRR's Avatar
Village Troll
18psi
Did you take the plugs out when you did this pressure test? Then rotate the engine to see if any coolant may have been in the cylinders?
Old Mar 13, 2011 | 08:55 PM
93z28ltone's Avatar
No I didn't
Old Mar 14, 2011 | 12:13 AM
  #32
SS RRR's Avatar
Village Troll
You need to do that. Keep the system pressurized for several hours. Take the plugs out and rotate the engine by hand. Make sure to look very carefully everywhere coolant passes. Just the slightest amount of moisture can mean it is leaking and if the coolant is hot then it'll evaporate before you ever notice. Did you check all the radiator seams?
Old Mar 14, 2011 | 01:26 AM
  #33
93z28ltone's Avatar
yes i did i spent a hour and half checking around the hoses and raidiator im about to give up and take it to a shop and see if they can tell me what it is
