loss of power + high rpm
Old Mar 13, 2011 | 01:44 PM
Mohammed's Avatar
Default loss of power + high rpm
well, I noticed some loss of power with high RPM ..
car has boltons and cammed , not tuned.
what's the problem ?
Old Mar 13, 2011 | 02:03 PM
nitrous2fast's Avatar
many things could be wrong. springs, injectors, valve seats, worn rings, cam specs, etc....
more info is needed. also a tune is in order.
Old Mar 13, 2011 | 02:05 PM
riceburnerZ28's Avatar
Did you have any problems before the upgrades. Did you check for codes? Dyno tune may help.
Mohammed's Avatar
it idles fine , accelerates fine ,but after accelerating and reaching top rpm ,it becomes slower ...
I think it's called engine bogging !!
just cleaned the injectors
what's the first thing to check ?? take it to a dyno ?
Old Mar 13, 2011 | 02:07 PM
Mohammed's Avatar
I didn't check for codes , but I got check engine light for a minute or two right after starting the engine and then it goes off.
Old Mar 13, 2011 | 02:13 PM
What exhaust are you running?
Old Mar 13, 2011 | 02:15 PM
Mohammed's Avatar
flowmaster
Old Mar 13, 2011 | 02:16 PM
Start with checking for codes. If you have access to a laptop you could datalog what the engine is doing while driving to pinpot the problem.
Old Mar 13, 2011 | 02:20 PM
Originally Posted by Mohammed
flowmaster
longtubes? shorties? stock manifolds? Size of the cam?
at what rpm does it "bog"?
What size injectors?
When did you do your last tune-up?
Old Mar 13, 2011 | 02:26 PM
Mohammed's Avatar
shorties,stock intake and injectors...
sorry i didn't check at what rpm..
i think i'll take it to the dyno this week
Old Mar 13, 2011 | 02:28 PM
SoxXpupPeT's Avatar
get the car tuned. you might be running lean. not good.
