close to solving opti issue!
Old Mar 20, 2011 | 09:47 PM
LigHtEmUp01's Avatar
Default close to solving opti issue!
so as some of u know i put a new opti on my car and it is a delco. i am getting a 36 high res failure code. this only happens after the car has been ran 10 min or so then it will randomly cut out. so i went over everything and think the icm may be the cause. i got it tested and it was good. i have heard of guys saying that when the heat up they mess up. so im gonna try one off a motor sittin in a garage but just wanted ur guys opinions.
Old Mar 20, 2011 | 09:59 PM
pro94lt's Avatar
I've found the opti gets the blame 90% of the time and is the cause 5% of the time. but I diggress. have you checked the harness. where did you get your opti? they are counterfited almost as much as Ben Franklin.
