rear sways a little to much!
Old Mar 30, 2011 | 07:19 AM
LT1Air's Avatar
Default rear sways a little to much!
My car likes to sway to the left under heavy acceleration and turning. I have an adjustable panhead bar. The busings on that are fine. I checked the rear control arms and their bushings are fine too. Any ideas on what else my cars the rear to sway.
Old Mar 30, 2011 | 08:41 AM
jester1614's Avatar
If your rear tires are the wrong size (too tall) that can give you the impression of driving on jello,
Old Mar 30, 2011 | 11:22 AM
Tbird232ci's Avatar
Did you check your swaybar endlinks?
Old Mar 30, 2011 | 02:23 PM
nitrous2fast's Avatar
Ok lets get a little more definite on the description..,...
Is it....
1: "swaying" like the entire rearend of the car is moving to the left.
2: "swaying" like the body is rolling to the left.
3: is your rear squating a lot under the heavy accel?
4: when your make a fast left turn does the back of the car seem to lift up or squat?
Old Mar 30, 2011 | 03:23 PM
jlpz's Avatar
I think he means fish-tailing..
Old Mar 30, 2011 | 03:27 PM
94LS1B4C's Avatar
Tooo much powa!!
Old Mar 30, 2011 | 03:28 PM
jlpz's Avatar
a bigger sway bar should help...
Old Mar 30, 2011 | 10:35 PM
05HD's Avatar
Your description is somewhat vague.
I have seen a broken gear carrier cause "sway" under load. It sheared right off at the carrier bearing and would walk out under load causing a rear toe change and steering effect. Car drove perfect otherwise and busted carrier was barely visible until the bearing caps were taken off.
