fuel line dryrotted, where does it go??
Old Mar 31, 2011 | 03:54 PM
grazi's Avatar
Default fuel line dryrotted, where does it go??
I have a newbie question for the pros.. My 94 T/A ..I notice sometimes I get a gas odor in the car. I jacked up the rear today and found driver side, back of the fuel tank up high, there is a rubber hose maybe 3/8" that is hardly visible going to a barbed fitting solenoid of some sort. It is totally cracked in half and seperated. The only thing that confused me was that there was no fuel residue on or around it. My question is could it be a fuel return or air/ vacuum line?? I only could jack it up a little bit where I was and it was impossible to trace it. Thanks alot if anyone can help me out
Old Mar 31, 2011 | 03:59 PM
bstuby's Avatar
Could be a evap line. Not really sure where your talking about tho.
Old Mar 31, 2011 | 04:04 PM
grazi's Avatar
I know its kind of vaque description... If I look at the space between the trunkpan and the fuel tank theres maybe a 1" gap. This hose is running right through there. Wouldn't I be seeing signs of a vacuum leak if it was an EVAC line??
I noticed, I'm prety sure that I only get the smell when I get on it...Would that mean that a vacuum line loses vacuum and actually has pressure making the smell? Just a thought
Old Apr 3, 2011 | 08:34 AM
bstuby's Avatar
Im not sure about the pressure. When I had probs with my evap, when I would get on it, I would get a very strong gas odor in the car
Old Apr 3, 2011 | 09:05 AM
SS1Eagle's Avatar
A pic would be helpful to locate the exact area in question.
I have a general idea where that line is but a simple macro digital camera with zoom will get you a quicker response and answer.
Here's my attempt to repair my fuel line off my dry rotted filter. This off a '96 Camaro. Get the GM 3/8ths line repair kit at NAPA.
