*Gasket* between block and oil filter??
Old Apr 2, 2011 | 04:24 PM
SStriker's Avatar
Default *Gasket* between block and oil filter??
Need help with the size and or part number for the gasket O-ring that is located between the block and the oil filter.
Looks just like the one that's on the oil filter but slightly bigger.
It's the part that is between the oil filter and the block (coolant lines go to it)
The car is a 94 Z
Any help is appreciated.
Thanks.
Old Apr 2, 2011 | 06:41 PM
squeals99's Avatar
pretty sure if i am thinking right you will find it in the help! section of most parts stores...for the oil filter adapter gasket set
can't tell ya the part number right off the top of my head but i know its in a green package
i know we carry it at the auto zone i work at
edit: part number is 82560
Old Apr 2, 2011 | 08:05 PM
SStriker's Avatar
Thanks for the reply and part no. But we bought that already and nothing inside that kit was what I needed. Those are all O-ring types. I am looking for the O-ring that is about 3" Dia. and about an 1/4" tall - Flat on top and flat on bottom.
