Coolant crossover
Old Apr 5, 2011 | 08:01 PM
henry172's Avatar
Default Coolant crossover
I just installed my lt1 coolant crossover pipe onto my heads today. I wanted to know if I did it correctly; I used one seal on the outer side of each bolt and put thread sealant on the threads, is there 1 seal on each bolt or is there 2 seals on each bolt?
Old Apr 5, 2011 | 08:23 PM
jasonisdn's Avatar
http://shbox.com/1/95-97_hoses.jpg
Old Apr 5, 2011 | 08:52 PM
robss96dcm's Avatar
There are 2 seals on each bolt, one between the head and the pipe and then one between the pipe and the bolt.
Old Apr 5, 2011 | 09:03 PM
Tinbender59's Avatar
does anybody have the PN's for these?? I can't find or rather the parts houses cant find them
Old Apr 5, 2011 | 09:06 PM
shbox's Avatar
The seals? GM # 10108689
http://shbox.com/1/steam_pipe_seal.jpg
But, you can buy much cheaper a/c or oil seals that do the same thing.
Old Apr 5, 2011 | 09:14 PM
hay thanks dude
Old Apr 5, 2011 | 10:37 PM
henry172's Avatar
That sucks I thought I needed 2 for each bolt, can you reuse them after they were already torqued down? Looks like I need to order 2 more or possibly 4.
Old Apr 6, 2011 | 12:48 AM
litch2004's Avatar
You do need 2 per bolt total of 4
 Michael S. Palmer
Old Apr 6, 2011 | 10:05 AM
jaycenk's Avatar
yea 2 per bolt. Anyone know if they are reusable with out issue if they are not that old and not torn?
