Pump seal
Old Apr 6, 2011 | 07:30 PM
henry172's Avatar
Default Pump seal
I am swapping in a edge stall in a few days I wanted to know if I should change the pump seal also. These are the seals I am referring to
What type of material are the larger seals made from?
Old Apr 6, 2011 | 07:34 PM
96capricemgr's Avatar
The only one you might consider would be the small one in the middle, the other two involve removing the pump, that inner one seals to the torque converter. If you aren't having any trouble with it I would leave it alone.
Old Apr 6, 2011 | 07:41 PM
henry172's Avatar
I did remove the bolts from the pump and replaced the o rings on each bolt then tq the bolts back down. I did change the smaller seal already; How difficult would it be to remove the pump and is it easy to screw things up?
Old Apr 6, 2011 | 07:54 PM
duh's Avatar
duh
it's a pain to pull the pump out. Not physically but getting it back right may not be for the average guy. I wouldn't recommend it if you're not having an issue with it. usually the smaller lip seal is the one that leaks, as most likely it either wears out or someone knicks it while installing the Tq. converter.
Old Apr 6, 2011 | 07:58 PM
henry172's Avatar
I am not going to screw with it then; it shifted fine when I removed it. I did notice a little bit of fluid on the bottom of the pump, but I think it is leaking from the front of the pan. I will be replacing the stock pan with a deep aluminum pan.
Old Apr 8, 2011 | 12:19 AM
henry172's Avatar
Being that the motor has been rebuilt with a lot of attention to detail I figured I should at least be sure all of the trans seals are new and sealed up. I decided to take the trans to trans shop near by and have them do a complete reseal minus the pan seal and filter. I am going to pick the trans up tomorrow with every seal replaced for $180; not too bad considering if I had installed it and ended up having to pull it out do to a leak. Lets hope the trans will hold for a while putting down close to 400rwhp.
