So I have lead on that problem pushrod help?
Old Apr 9, 2011 | 04:35 PM
bizerk1's Avatar
Default So I have lead on that problem pushrod help?
So that problem i had with that ticking noise and the video i had before for it turns out its probally a bent or lose pushrod i was only able to get the valve cover up a little so cant see anything but it was felt. It wiggled when was turning it. My question is if i bent the pushrod is the valve damaged or could the valve still be ok or be salvageable sp i can just change the pushrods and rockers only?
Old Apr 9, 2011 | 04:38 PM
jester1614's Avatar
the valve might be ok, but if the pushrods are bad the valve obviously hit something. the save bet is to pull the head and check the valve, or at least do a leak down and compression check.
Old Apr 11, 2011 | 01:49 PM
bizerk1's Avatar
well if i pull out the heads should i just get new heads and all the internals , what heads are good for stock block and that would go well with a 383 in the future?? What kind of number gains are we talking or rwhp?
Old Apr 11, 2011 | 02:03 PM
James Montigny's Avatar
You don't have to pull the heads, you should at least do a leak-down test first so you know what you are dealing with.
If you really want to do heads, you can certainly port stock heads for use with either the 350 or a stroker.
H/C 350s put down 380-420 without much trouble. How much power you make
really depends on how much you want to spend and how much cam you are willing to tolerate.
http://elliottsportworks.com/ <-- this guy can help you out
He certainly helped me with both my 350 and my 383.
Some of the guys have had good luck with http://www.advancedinduction.com/ as well
Old Apr 11, 2011 | 02:32 PM
bizerk1's Avatar
yea for those le's would I have to get Le1 or le2 do i send him my heads or i buy a new pair from him and did you install ur heads or have someone do it , im tryin 2 figure labor cost out
Old Apr 11, 2011 | 02:43 PM
bizerk1's Avatar
is it fairly easy to take off the heads I have the driver side's valve cover almost off but i need to get a wrench to move the egr thing that runs into the headers are out the way so I can pull it off
Old Apr 11, 2011 | 02:46 PM
You can
a) send him your stock heads
b) buy a set of used Lt1 heads for $175-$200, OR
c) buy a set of aftermarket castings for $1100+ (Dart, TFS or otherwise)
I have done my own heads on a few projects, I've also had other people do them for me.
It's not terribly difficult if you have basic tools, jackstands and some free time.
Here's the documentation from my H/C install a few years ago
http://www.cardomain.com/ride/229715...irehawk/page-4
Old Apr 11, 2011 | 04:44 PM
bizerk1's Avatar
that was nice power jump, did u move the egr to remove valve cover and heads?, is there an actuall forum for a unistall heads and install of head guide?
Old Apr 11, 2011 | 05:28 PM
mguidry629's Avatar
If you're pulling the heads, then you're gonna want headers, especially if you get them ported or get aftermarket, so I would pull the EGR and gently place it in the trash. Then roll it to the end of the driveway.
Watch for the coolant x-over tube bolted to back of the heads. Make sure you don't damage that or strip the bolt head when removing the heads.
I've never pulled the heads with the motor in the car, so I don't know of any guides, but it's just nuts and bolts. I would have a professional re-install and adjuster rocker arms, etc.
Old Apr 11, 2011 | 07:01 PM
The EGR needs to be removed, as do the intake manifold and valve covers.
Use this as a guide http://shbox.com/ci/cam_removal.html
and this to put it back http://shbox.com/ci/cam_install.html
You can do all of this with the motor in in the car.
Old Apr 12, 2011 | 02:32 AM
bizerk1's Avatar
good I want to leave the bottom end in
