idle issues with new cam
Old Apr 10, 2011 | 12:43 AM
ThorsLT1's Avatar
Default idle issues with new cam
So main issue im having is when comming to a stop the car tends to die. Any suggestions? Should I change the set screw for the TB?
Old Apr 10, 2011 | 12:47 AM
RamAir95TA's Avatar
Tune? Details?
Old Apr 10, 2011 | 12:58 AM
jsteele90's Avatar
if you havent had it tuned since the cam install. then....... there is your problem
Old Apr 10, 2011 | 01:05 AM
stangtrader's Avatar
His car is untuned currently car just got back on the road.
Hey try slight adjustment on set screw going no more than 3% total using your scan tool to monitor real time,then turn key off unplug tps turn key on and verify 0% tps, then key off and reconnect. I'd still try that method but start out slow and remember how much you turn the screw. Should work. Main thing your trying to achieve is more idel air flow since the iac will not be able to keep up. When you get your tune the iac counts will be readjusted then you should be able to return the set screw. You lt1 guys concur for a cammed lt1 even though this is true for my ls1?
Old Apr 10, 2011 | 08:00 AM
355z28's Avatar
Might help, but it will always drop down like that when coming to a stop. Coming off throttle is a important part of the tune. Several mail order tunes Ive had will have a slight problem in that area and will take a little work to get it right.
Old Apr 10, 2011 | 12:58 PM
BALLSS's Avatar
I would suggest not messing with stop screw and have the car tuned for the cam. SOP for a cam swap in LT1
adjusting the stop screw has negative effects on TPS volts and IAC counts.
after tune the owner "may" also find it necessary to drill/enlarge the IAC hole on TB to resolve possible idle issues. This should not be done without first scanning car to read IAC counts (30-35) and TPS volts (.67vdc closed & 4.5vdc full open). Tuner will assume the TPS & IAC is set right.
