Which AFPR fits a 93 Fbody?
As I understand it, there are four designs for LT1s and the 93 is specific to that year.
I keep seeing parts listed as 93-97 though.
Problem is, I can't tell which ones really fit both (IE: have left and right mount brackets) and which are just typos.
Yes, I understand how the AFPR works
Yes, I have a specific application requiring more than stock FP
Yes, I plan on tuning for it
Although I have seen several setups (including Lethal's) and they do look awesome,
I don't really want to run an external AFPR with AN fittings unless I have to, the stock size lines are
more than enough for what I am doing. Then again, it would be nice to get them out of the way.
I can't tuck 93 lines the way you can 94-97 lines unless I hack them off and use flare or compression fittings.
For example.
My stock FPR looks like this; (tab on left)
While a 94-97 AFPR looks like this; (tab on right)
I found this : http://www.fbodymotorsports.com/inc/sdetail/9464
But it basically means hacking up a stock FPR. I really don't like that idea.
I also found Accel PN 74565 that looks like it will fit, but it's backordered for a month.
I lost the pic of the bracket, but it wasn't pretty.
If I have to fabricate, I'm welding AN fittings.
A local shop was willing to do the AN fittings and had all the parts in stock, but I really can't justify it now.
I can put that money to better use
