Crankshaft hub
My 95 LT1's crank hub, the thing that holds the balancer, is not keyed. The balancer (SFI) only goes on the hub one way, and the outer edge has degree marks like a regular balancer. So, what's the use? Does it just go on in any position?
The hub crushed the key into the timing chain sprocket, had a hell of a time getting the sprocket off. I'm assuming it was the wrong key? Need to replace the crank sprocket and chain, cam sprocket looks good. Looked up a timing set and had cardiac arrest!
Al
Al
What kind of waterpump setup are you running? If you convert to an electric pump, you can run just about any SBC timing chain, including double rollers like the Cloyes 3145.
The 93-95 key is smaller and only drives the timing set.
The hub itself should not be able to touch that key.
Since it's neutral, it can be installed in any position even if the crank pulley only installs on the hub one way.
So yes, the timing marks are pretty much useless in this case.
If you build a motor and have a full key installed in the crank, you can use it to keep the balancer
lined up and it's timing marks will be useful. I use this for adjusting rockers, it's nice to have.
This is similar to what I did http://www.go-fast.org/z28/damper.html
(I've been using Dave's site as a reference tool for years, it's good reading)
