plug hole for low coolant sensor?
Old Apr 13, 2011 | 02:37 AM
nighthawk15's Avatar
Default plug hole for low coolant sensor?
My low coolant sensor literally blew off the radiator the other day and caused my car to severely overheat. I have no idea what caused that and for some reason I can't seem to get it to stay in there without leaking now. I was wondering though, has anybody just plugged that hole somehow? I was going to/probably will just try replacing the o ring on the sensor and see if that fixes the leak issue, but i would kinda rather just plug it if there's a good way to go about that.
Old Apr 13, 2011 | 03:35 AM
green95vert's Avatar
I did before I got my Griffin. Take the old sensor to an auto parts store and have them match it up with a rubber freeze plug (kind with a nut on it so itll expand and seal the hole). Worked great for me. If I would've thought about it I'd have saved my old one before I tossed the radiator a week ago lol. Its a small one, a 9/16, 5/8, something like that.
EDIT: Be careful NOT to crack the plastic end cap when you tighten it.
Old Apr 13, 2011 | 03:59 PM
qc97z's Avatar
Same thing happened to me a few weeks ago OP.
On mine, the retaining clip was bent a bit and wouldn't hold on to the upper and lower barbs on the radiator at the same time. I pulled the clip, bent it in a bit more so it would clamp tighter, removed the battery (to get access) and made sure the top and bottom of the retaining clip were set properly. No problems since.
Old Apr 15, 2011 | 05:46 AM
I think I'm gonna try this. Thanks for the idea!
I think that might actually be similar to the issue with mine.
