Heads Cam Combo
Old Apr 20, 2011 | 10:11 PM
etrnl_velocity's Avatar
AI looks great for the money!
Who is LE?
Old Apr 20, 2011 | 10:13 PM
coolmanvette75's Avatar
Originally Posted by etrnl_velocity
Who is LE?
Lloyd Elliot
Old Apr 20, 2011 | 10:36 PM
LSWHO's Avatar
Originally Posted by SS MPSTR
I think you misread it. Dwayne was referring to the quote above his regarding still not appearing to know which way to go. It wasn't a "crybaby" response - at least I did not read it that way.
If that is how he meant it then I partially retract my statement. Partially because only a great fool would take Internet responses as gospel right off the bat. Research and thinking is the logical path.
I suppose he could have said that in regards to the iron head indecision and that shouldn't require research or thinking. The head porter and the Internet told him the same thing. If this is the case then I fully retract.
This is why quoting helps on message boards. So you know who and at what comment they are responding to...
Old Apr 21, 2011 | 10:44 AM
MoparChevZ28's Avatar
Although I must admit, I am a little puzzled because the coolant is in the valley. Is it possible for it to get into a combustion chamber and sneak through an intake valve and into the valley?
Also When I put the 93 lt1 in my car is there anything else I need to switch to run my computer besides my intake, cam, and knock sensor?
Old Apr 21, 2011 | 12:06 PM
duh's Avatar
duh
to run the 93 in your car, you will have to pull the timing cover and put the original timing cover (with crank sensor), crank reluctor, crank hub, opti, throttle body, and if you choose to the intake. You will also have to move the oil pressure sending unit to the top of the engine where it is originally located on the 97, and you will have to swap the 97 injectors in if you decide to reuse the 93 intake. That's about the extent of the differences between the engines. Oh, yeah you need to put the 97 cam into the 93 engine as it has a different drive system for the opti and the 93 cam will not be able to drive the later model opti.
Old Apr 21, 2011 | 01:16 PM
I was going to use my cam, opti and intake with the 30# injectors because thats what my computer is tuned for. Relocating the oil sending unity shouldnt be too hard. My question is What is the difference between the crank hub, and the reluctor. Also what do you mean by the original timing cover? The original timing cover to the 93 or the 97?
Btw. the 93 motor is complete, just has a shitty opti, so I was going to swap the opti and cam anyways.
Old Apr 21, 2011 | 01:18 PM
WS Sick's Avatar
Or you could swap in an OBD1 puter and get the harness from the main harness to the opti, use the 97s coild and IGM, Adjust with tunercats the injector offset.
Old Apr 21, 2011 | 01:19 PM
WS Sick's Avatar
In light of that, swap all that over and use your stock puter, make sure to use the 97 coil as the 93 is a dual connector.
Old Apr 21, 2011 | 04:46 PM
duh's Avatar
duh
you need to use the 97 timing cover, crank reluctor (the 93 doesn't have one because of the OBDI) and the crank hub as it's shorter due to the crank reluctor. While you're at it, you may as well pull the crank gear for the timing set as the keyway on the 97 is a little bit longer to accommodate the crank reluctor as well. Unfortunately the swap from the 93 to the 97 is not the least labor intensive of LTx swaps.
Old Apr 21, 2011 | 11:19 PM
Gotchya, That clears it up for me. A lot actually. Yeah I agree. Was I right about the knock sensor? Does that have to be swapped?
Old Apr 22, 2011 | 06:17 AM
RamAir95TA's Avatar
If you use an OBDI PCM, you need an OBDI knock sensor, and vice versa for OBDII.
