What can I expect with these mods.
Old Feb 21, 2004 | 02:09 AM
SSC5R's Avatar
WARNING! Bad Seller Alert
Question What can I expect with these mods.
Ported Lt1 heads and intake, 1.6, TB 58mm, powerdyne SC 9lbs of boost, 383, Lt headers, borla, solid roller, LT1 edit.
Don't know what cam to get yet but I know its going to be a solid roller. All this is going on a T56 car.
Old Feb 21, 2004 | 10:41 AM
Fastbird93's Avatar
How good are the heads, and how big on the SR setup..
FWIW, I haven't heard of a SR/Blown setup yet. Could be interesting. I'd say you're looking at 600 easy if the combination is right. You figure a good SR 383 will be at 450+, and a 9PSI blower can easily add 150+ on top of that. It's all in the combination though.
Old Feb 21, 2004 | 05:49 PM
SSC5R's Avatar
Heads flow 270 @ 600 and not sure yet on what cam specs that I will be using. Think of going with a AFR head instead. Possiably a AFR's 210 head.
