Piston/Cam Questions.
Input greatly appreciated.
I'm running domed pistons in my new build and I can tell you the only way to know for sure what the clearance is going to be is to mock it up and MEASURE. No one on here is going to be able to tell you.
That being said, a properly designed aftermarket piston should have enough valve relief to run way more cam than that. These are SBC pistons and there are plenty of much much more radical setups out there that dont have to worry about PTV issues.
.02
The LT1 stuff is small chamber and with good quench and a flatop piston ends up 11.5:1+ in a big hurry, which is a good thing but a dome will go way too far way too fast. Plus as I eluded to it is unlikely the dome and chamber will fit eachother without some tweaking.
Like stated, with LT1s relatively small chambers you can have some physical issues running a domed piston, especially on larger valve heads. For example, my AFRs have the intake valve literally protruding from the surface of the heads. Along with a long duration cam(which has more effect on PTV then lift), you can run into problems quickly.
You will have to carefully spec the valve events with the cam and measure,measure,measure.
Honestly unless you have the money to spend testing it out I would just sell the pistons and get some traditional -5cc flat tops.
