The new problem
Old Apr 27, 2011 | 08:15 PM
sempire's Avatar
Default The new problem
Just got my stall installed tonight and afterwards it seems that my car is vibrating to hell. In drive, neutral, park etc, it will vibrate roughly if you give it any gass, I noticed around 140kph it smoothens out, but I'm trying to figure if it's a sensor or vacuum leak or something else.. I need some suggestions.. Maybe something was pulled out when we moved the transmission.
Any ideas?
Old Apr 27, 2011 | 09:30 PM
rich5368's Avatar
Sounds like something is out of balance. May need to double check the fly wheel and such and make sure they are balanced right.
Old Apr 27, 2011 | 10:15 PM
sempire's Avatar
But it happens in park and neutral too..
Old Apr 27, 2011 | 10:31 PM
LSWHO's Avatar
The flywheel is attached to your motor... The crank doesnt stop spinning in neutral...
Old Apr 28, 2011 | 01:07 AM
Big Al's Avatar
May be something as simple as a missing converter to flex plate bolt. Take it back and let them worry about it.
Al
Old Apr 28, 2011 | 06:17 AM
RamAir95TA's Avatar
I bet they didn't seat the converter fully on the pump and didn't clearance/shim it to the flexplate, installed the flexplate backwards, didn't fill the converter with fluid, didn't tighten down the flexplate-to-converter bolts properly, or didn't use the correct hardware to fasten it to the flexplate.
One of those things, probably.
Old Apr 28, 2011 | 07:59 AM
sempire's Avatar
The converter was filled with fluid, the flexplate was stock, the hardware to fasten it was stock, the converted seemed seated... everything was done except shim it.
