my dyno results
Can you explain this?
And your car should run low 11s. Unless you are in Denver or gregrobs neighbor.
To give you an idea... My car ran 12.70 cam only with no traction, 8' of knock, a VERY rich tune, at 1700' density altitude.
In my first post, I calculated the ET to HP conversion in Wallace Racing calculators and it gave me 390HP for a 3500lb car to run 12.3. I know it's not possible to be accurate but it gives you an estimate of what HP you need to hit a certain ET or vise versa. I just thought I would share that with the OP, but that was obviously a mistake.
Just decided to check out Wallace Racing and see what HP it says for 11.5ET at 3500lbs, and it gave me 479HP at 2300DA. I assume that's rear wheel, but it may be flywheel. So with the 280xfi on a 383, I should be looking to put 450-500hp at the wheels? Camquest has it peaking just under 400fwhp at 5500. Camquest is also not accurate according to a few on here. So where do you get accurate information? Experience I guess. Which I'll admit I don't have much, so I'm on here soaking up the knowledge.
You are right, a lot of folks don't like my input, at least at first, a lot of them also later send me PMs or emails saying "you were right about everything". That is not what I want to hear from folks, I would rather hear they got things right the first time because they listened when they asked questions.
IMO you should be Making more HP for sure
12.6 and MUCH better has been done via bolt on LT1 power
SSSSOOOOOOO many people really halfass their research and then blindly defend their mistakes OR do a complete 180 when they make a mistake and never work through it. They seem to apply those wrong too, there are mistakes you should walk away from and start over but those are the ones they defend, and in those cases where they need to stick to it and work it out they run away, sell the car or go back to stock or swap in an LS that they never make run right either.
my 305whp 3550lb rw car went 12.1s @ 111 @ 2800' da. it was a big stall a4 bolt on ls1 car. dynos don't mean ****.
