Ls7 lifter preload
Old May 2, 2011 | 03:38 PM
the_merv's Avatar
Veteran: Air Force
Originally Posted by Big Al
Your math is correct, except you are moving the center point, not just one end. Think about it.
Al 95 Z28
You move the centerpoint in the LS's aswell..
Old May 3, 2011 | 11:24 PM
Zbinkley's Avatar
Originally Posted by SoxXpupPeT
I had tryed that in my car. As im slowly doing them with the engine running it started to run like crap!
I have mine set at 1/4 turn. I might fool around and see how they respond at 1/2 turn
OK correct me if im wrong, but you cant just "fool around" and try 1/2 turn vs 1/4 turn. There is a torque spec for these bolts and the idea is that when you reach that specific torque you should be at X amount of turns. In order to change the number of turns it takes to reach that torque is dependent on pushrod length.
Old May 4, 2011 | 12:54 AM
jaycenk's Avatar
You can try what ever you want with polly locks.
Old Aug 15, 2011 | 01:39 AM
red 454's Avatar
i'm assuming that all the replies here were using adjustable rockers ??
Old Aug 15, 2011 | 06:03 AM
RamAir95TA's Avatar
Define adjustable rockers. Every SBC-specific rocker preload is reliant on infinite adjustability on the poly lock.
Old Aug 15, 2011 | 07:23 PM
red 454's Avatar
i think i was in the wrong section im looking for lsx /ls7/ls3 preload with yella terra adjustable roller rockers
Old Aug 15, 2011 | 07:35 PM
shix's Avatar
https://ls1tech.com/forums/advanced-...l#post15273617
saw this as i was scrolling down to lt1 section. thought it might help
Old Aug 15, 2011 | 08:25 PM
Jon A's Avatar
Hmm. Interesting thread. I guess I'm the odd man out. I'm running them just a hair past 1/12th turn. Seems to be working pretty well.
