Picked up an early borla adjustable
Old Apr 30, 2011 | 02:05 PM
jaycenk's Avatar
Default Picked up an early borla adjustable
Hey guys I found a Borla cat back (the adjustable Plate model with 2 pipes comming out the drivers side) for a 94 or 95 camaro that I picked up for 100 bucks in decent shape. Anyone know what E cut out I can use on this thing? Anyone have a link to these? I also have to adapt it to the LLP ORY. This Borla has the S curve pipe with a 2 bolt flang on it for I guess single cat cars. I'm gonna see if I can use the short pipe from my SLP loud mouth to make it work but if someone has done this before please post up what you had to do to make it fit dual cat cars. Thanks
Old Apr 30, 2011 | 03:32 PM
Big Bad Bud's Avatar
I bolted this one right in on the rigth side
http://www.summitracing.com/parts/SUM-670150-1/
Old Apr 30, 2011 | 04:10 PM
SStriker's Avatar
I think the beauty of the adj. Borla is that pretty much all the E-Cut outs will work. I am using a QTP 3" on it. Bolted right up.
Old May 1, 2011 | 12:46 PM
95mysticta's Avatar
Have a 3" QTP in mine... works good but i would make sure to get a better opening tool as i have the toggle where you never know exactly where the plate is and might over blow the motor if it goes too far. I want to be able to flip the switch and it be 100% open or closed.
