Flywheel Bolt Spec ?
Old Apr 30, 2011 | 05:01 PM
LT1FirebirdSLP's Avatar
Default Flywheel Bolt Spec ?
I have a 1994 LT1 that I am putting back in my car as we speak. Unfortunately I can't find the flywheel bolts to save my life. I believe its a 1 pc Rear Main.
Does anyone know the specs on these? There are 6.
Any help would be greatly appreciated, I already googled and searched the heck out of this.
Old Apr 30, 2011 | 05:27 PM
shbox's Avatar
7/16-20 x 31/32 but you should really get some real flywheel bolts either aftermarket or from the dealer, so you know they are of proper strength.
Old Apr 30, 2011 | 06:50 PM
stevo9389's Avatar
i don't think i found the correct lengths in any of the hardware stores in my area. ARP ones are pretty easy to find so i just bought a set of those.
Old Apr 30, 2011 | 09:45 PM
SilverSS07's Avatar
The only local place I could find them is NAPA. Call them and tell them what you're looking for. They should be able to look it up.
Old May 1, 2011 | 01:40 AM
fex77k's Avatar
I bought some cheap ones and they damn near rounded out, put some ARP's on and haven't had to worry since.
Old May 1, 2011 | 08:33 AM
SS RRR's Avatar
Village Troll
http://www.summitracing.com/parts/ARP-200-2807/
If you get the ARP's, make sure it is this part number. These are for a one-piece crank. The two piece crank bolts have a larger head which will come into contact with the flywheel centering flange on the crank.
Old May 1, 2011 | 06:58 PM
ElkySS's Avatar
i believe u can just use some from a 1 piece sbc
Old May 1, 2011 | 07:03 PM
ringmaster72's Avatar
I got some from napa, but they were shorter and I did not want to take a chance so I bought some from the dealer. $20 well spent.
Old May 2, 2011 | 12:10 AM
itSSlowZ28's Avatar
ARP's here. put them in with some loctite and forget about them
