383 build
Old May 2, 2011 | 09:09 PM
quientelle's Avatar
Default 383 build
hey guys got a question on my 383 build.i have a le2 set on 350.i will be taking that le2 setup and install it on my 383 build.but also talk to lloyd about his trickflows heads with the 2.08 1.6 valves.he said they would be about 20 hp upgrade over my stock ported le2 heads.with the stock ported le2 heads my compression would 13.3 to 1 and the ported trickflows with milling would be 12 to 1 compression.by the way i will be running a 242 248 camshaft with 110 lsa.which setup would be better?and also cfm or compression.thanks
Old May 2, 2011 | 09:19 PM
AChotrod's Avatar
If you got the cash lower compression and more HP is always better. What fuel do you plan on running?
Old May 2, 2011 | 09:24 PM
quientelle's Avatar
93 octane with toulene.also will the extra compression make up for the 20 hp on the trickflows.
