engine block warmer/heater?
Old May 5, 2011 | 03:32 PM
quik95lt1's Avatar
Originally Posted by 96capricemgr
I never had a problem with my LT1s starting be they 50k mile or over 200k mile and every winter I have owned them at least one of them has been asked to start in teens below zero. Have seen -20f even without any issue but the PS pump growling for a moment and the shocks stiff as hell.
You have a mechanical or electrical issue that needs attention.
what he said ^
if my massive cam race motor will start and idle on its own in 30* weather your's should too.....
Old May 5, 2011 | 03:33 PM
quik95lt1's Avatar
Originally Posted by gregrob
X2
And have you pulled the trouble codes? I would do a compression test.
what he said too ^
Old May 5, 2011 | 06:16 PM
chasehammer's Avatar
fuel pressure is about 42psi
it is throwing only one code P0173, Bank 2 too lean. i have another thread about that though and still waiting to install the o2 sensor.
