Is this car worth it?
I paid $4,000 for my 98z and $4600 for my 99SS
So i honestly dont see how many of these lt1's sell for more then 3k but as you said jaycenk, stupid people.
It was in Miami and they thing was in good shape, cloth interior, maroon. Went down and took it to a shop and put it on a lift, no damage just a high milage 120k camaro with out many options. Clean title actual milage od statement too. FWIW on the ABS i used to have weird ABS issues where my low trac would come on for no reason (like going 5mph on dry pavement and applying the brakes to stop) and after doing that and having the brake pedal get really stiff 3 times the ABS inop would come on. once i got that problem fixed (new rotors and pads cured it) the only time i've ever seen the abs inop light was when my battery was low (not necessarily requiring a jump start but with a slow crank) and it would come on solid right away like that one did. if i let the car run for a minute or so, shut it off and restarted it, the abs light would go away and the system would be fine. thats why i always figured that it took more juice to run the abs than to start the car. I had a bad battery for 2-3 years without knowing it. i replaced a battery in 2005 or so and if i let the car sit for more than 3 days it wouldn't start. i once replaced the alternator and that didn't fix it so i thought it was my aftermarket alarm draining the battery, then i removed that once the remotes started going bad, finally i replaced the battery just because the warrenty was getting ready to expire and i figured maybe it was the actual cause. i was right, lol. my now 3 year old battery cranks the car up every time. i left my car in the garage for 10 days a few weeks ago while i was out of town and when i got back, i cranked it and it fired right up.
