Newbie with questions?
First off: adjusted rockers because of chatter, now car sounds different and doesn't feel like it did before rockers started chattering.It don't seem to pull as hard above 3000 rpms and it acts as if it straining to go over 3000.
When i adjusted the rockers i twisted the pushrod until it stopped then 3/4 turn.Is this correct or should u twist until u feel drag then 3/4 turn or 1/2 turn.
Second: on the dyno it only made 324hp.I bought everything from a friend and in his car made 360hp only difference was 4.10's instead of 3.73 and he had an aluminum flywheel.Is something wrong or is it this all she has? Any help or opinions would be greatly appreciated?
