ALDL will not connect
Car is a 94 obd1 car
Car has power at the fuse
we jumpered the aldl and the fans cut on
disconnected the pcm and reconnected
Still nothing. The car starts up and runs just fine so the pcm isnt dead or anything crazy like that.
Any idea on what could be going on here.
Thanks
Edit: I may have mis-read. You mentioned ALDL so I assume your using a laptop, but if you're using a scanner, then ignore the above.
We tried:
An OTC 4000 matco tools obd1 scanner
A Genisis techforce scanner
also a laptop that had data master
And I also tried to download freescan on to the lap top and that didnt work either
This is a 94 model year car so it does not have a powered aldl connection on the car
hth
andy schuck
. I have a 95 GMC Jimmy with OBD "1.5"- half OBDI stuff and half OBDII stuff
. That's why I had the cable and scanner that would read both lol hth
andy schuck
Fuse for the cigarette lighter? Would this cause the scanners not to connect?
