396 Stroker SR build FTMFW!
Build:
96 Camaro 6spd with 4.30's
396
12.5.1 CR
Ported 364's
290/198 @ .600 206cc 62cc(no pipe) 2.02/1.60
Ported stock intake
58mm PP TB
Ed Curtis Spec'd cam 244/254 .640/.640 112
LT/ORY/Magnaflow CB/cutout
Supporting fuel system.
Dyno'd:
432/411 @ 5950 thru open cutout
422/403 @ 5950 thru CB
Tuned by GPI in Jacksonville, Ar.
On a Dynomite Dyno. He compared it to a mustang dyno.
I was a bit disappointed with the numbers, but we'll see how it does at the track!
The Torque curve is immediately over 400rwtq at 3700-5200, and yes, flat until it maxed Tq at 411 @ 5200 and falls off afterward.
The HP curve is strong from the initial 3700 to 5300, then tends to slow off peaking at 5950 and flat lines until he lets off at 6300
.I'm sure your power curves are awesome and it's a blast stoplight to stoplight, but a SR 396 is past the point of ported stockers. If it plateaued and held it at only 6k RPM and didn't just drop off, its not valvetrain or tune - the heads are too small. Some worked aftermarket castings like TFS or AFRs will give you a few hundred more RPMs and I can see +20hp to the wheels over what you have. Brodix also makes a nice SBC head that they will convert to reverse cooling for you, and of course we have a massive selection of nasty *** SBC stuff that will work with some machining.
AI has a nice TFS package but they may not want to work with you since you didn't get the cam from them and might want to change it. AFRs can be done up nice by a lot of reputable shops that may or may not have an internet presence - they are huge in the SBC community.
It's up to you to decide whether ~20hp for ~2K is worth it
. Keep in mind also if he said his dyno reads similar to a mustang dyno then it will already show a bit higher on a dynojet.**edit**
Hell, thats small for a hot 383
. Also, feel I should mention this.
Car ran great on dyno day. Drove home about 45 miles(didn't pull I high at all, had my son with me). Parked it for 2 days bc if rain. Then the lady and I decieded to go see a movie in the car.
I took it on hwy about 60/3rd, pulled to 6300, shifted to 4th and pulled to 6300 and hit the clutch. Immediately heard a noise. Pulled over and pulled the valve cover found a lifter collapsed. Did some research and saw that the Comp 875-16 has had problems such as this.
I called Aaron at comp and he shipped me another set, no questions asked. Afterward we discussed why/how it failed.
He said the 875 has a low tolerance to preload. It only required about an 1/8 turn. I had them set to 1/4 or maybe a hair more.
I wouldn't think that would hurt me but hell, I've been proven wrong before lol
