Misfire found. Finally.
Old May 18, 2011 | 09:29 PM
duff man's Avatar
Default Misfire found. Finally.
Thanks to Warren (The Engineer), my high RPM misfire is no longer a mystery. A loose rotor screw was the culprit. Longer screws and loctite are in place. Just awaiting reassembly. I really want to thank Warren, as I have never done anything like this myself. Hopefully he will show his new setup at the next shootout. I heard it run. Pure .
Old May 18, 2011 | 11:15 PM
SoxXpupPeT's Avatar
Glad you found your miss. My miss was from a faulty opti aswell. That sure is a purdyyy garage hes got there!
Old May 19, 2011 | 08:41 PM
God's LT1's Avatar
Is that a cavalier in the middle?
Old May 19, 2011 | 11:16 PM
duff man's Avatar
Yea. That's Warren's tube chasis car. Not really a cavalier except in shape.
Old Jun 4, 2011 | 09:11 PM
marc1130's Avatar
how many miles were on your opti mine has 160,000 and i think i have the same problem. I plan on buying a new gmhp unit should I disassemble it and use some sort of special loctite on the rotor screws before i install?
