Low oil pressure
Old May 19, 2011 | 09:27 PM
uzeial's Avatar
Default Low oil pressure
So, my new lt1 is driving me crazy. I recently replaced the previous motor with a Jasper motor and now after it gets warmed up the oil pressure drops to maybe 10psi at idle and acts like it wants to fluctuate a little. I realize 10 is within GM's parameters, but it scares the hell out of me. Is there a way I can fix this without having to tear the motor apart?
Thanks
Old May 19, 2011 | 10:00 PM
transbird95's Avatar
Did you verify the pressure with a mechanical gauge? is the engine running smooth? If there is a problem some where it will have to be torn down to some extent depending on what you find.
Old May 20, 2011 | 08:44 AM
uzeial's Avatar
Thank you foryour quick response. I will do a mechanical gauge check today. Hopefully it's just the oil pressure sensor.
Old May 20, 2011 | 10:19 AM
greenz28in503's Avatar
Did you reinstall the oil cooler from the old motor? My oil pressure at idle went up quite a bit after I removed it (it started to leak).
Old May 21, 2011 | 03:19 PM
uzeial's Avatar
The mechanical gauge has my oil pressure hanging around 17psi. Thanks for your help! I'll get around to changing the sensor a some point.
