Quick Q- Clutch disk orientation
The cluch disk has no markings
Thanks in advance
On one side of the friction disk the "spring cage" around the hub will stick out, while the other side of the disk looks pretty much flat. The side that sticks out faces the flywheel and the flat side faces the pressure plate.
Pressure plate bolt torque is only 22 ft lbs, use loctite.
