cc503
Old May 23, 2011 | 04:54 PM
95formulalt1350's Avatar
Default cc503
ok i got a 95 formula with forged 355 ported heads and intake but im trying to pick a cam that is not to big but not to small and i was just wondering if the cc503 is a good cam with my combo or would it be to small ?
Old May 23, 2011 | 05:16 PM
gatorhead's Avatar
The 503 is a nice little cam. There isn't a whole lot of info to go by on your engine to recommend a cam. Compression ratio, flow numbers, auto/manual, gears etc all would help alot.
The 503 is a good mid range cam on stock heads, of course the rpm band would shift depending on how the heads flow.
You are going to see alot of custom cam responses etc. I honestly have nothing bad to say about the 503
Old May 23, 2011 | 05:44 PM
ZGOBYBY's Avatar
The 503 is a cam that is optimized off of stock unported heads, there are better choices out there. See the cam sticky thread in this sub-forum.
Old May 23, 2011 | 07:40 PM
trilkb's Avatar
could do a cc503 with 1.7 rockers, would bring the valve lift up to .573/.578
Alot of people talk about it but i dont think ive seen anyone do it, you have a good platform to try it out on!
Old May 23, 2011 | 09:36 PM
well i gotta gears a 3500 stall 3.73 gears .its a4 and trans is being built now.its gonna have 10.4.1cr.
Old May 23, 2011 | 09:37 PM
sorry about the bad typing
Old May 24, 2011 | 06:33 PM
TravisMcGill2000's Avatar
Ill be the first one to say it. Get a custom cam. Call llyod or ai both are great. If u dont have the motor already together. Id go for higher compression then 10.4.. U need try and get it to 11.5 or so.
Old May 24, 2011 | 06:36 PM
LSWHO's Avatar
Definitely spend $200 more on a custom cam that will net you 3 extra hp.
Old May 24, 2011 | 06:54 PM
ur rite every1 should use off the shelf cams.
Old May 24, 2011 | 07:05 PM
trilkb's Avatar
think the benifits are a little more then 3hp, plus when someone asks you "is that a 503? is that a 306? is that a hot cam? is that a gm847? is that a....." you can say NO!!! I AINT NO QUEER!!!!
Old May 24, 2011 | 07:07 PM
nitrous2fast's Avatar
Hey no one said anything about queers.... Why you gotta bring up that crap?
Old May 24, 2011 | 07:41 PM
LSWHO's Avatar
You guys are silly. You are calling a shelf cam a custom cam. If LE tells you to use one of his grinds guess what? It's still a shelf cam. You just paid more for it. Also, show me dyno/track proof of these "custom" cams running better. They are negligibly better at best.
Hell I'm running an LE cam.
Why are you calling queers crap?
Old May 24, 2011 | 07:55 PM
camar0corey's Avatar
I'm going to be running a 503. You know why? Because I had it laying around. I wasn't about to drop more money for maybe 10 more horsepower.
The Formula it was in previously felt a lot nastier than my hotcam car, so I can't wait to see how this is going to turn out.
Old May 24, 2011 | 08:06 PM
coolmanvette75's Avatar
I would look into the AI shelf grinds. Their 230/238 (.575/.575) has proven to be an amazing cam. With head and intake work you might be able to run their slightly bigger 234/242 (.575/.580)
Old May 24, 2011 | 08:13 PM
whytryz28's Avatar
lol
The message you have entered is too short. Please lengthen your message to at least 5 characters.
Old May 24, 2011 | 08:16 PM
Haha no pun intended I guess.... I wasn't calling queers crap, I was calling his statement crap.
Old May 24, 2011 | 09:44 PM
lt1-xjs's Avatar
[QUOTE=LSWHO;14955217]You guys are silly. You are calling a shelf cam a custom cam. If LE tells you to use one of his grinds guess what? It's still a shelf cam. You just paid more for it. Also, show me dyno/track proof of these "custom" cams running better. They are negligibly better at best.
I agree. There are only a few good grinds that work, whether Comp, LE, or AI or whoever. They are small, medium and large. You and atleast 20-30 others have the same "custom grind", or off the shelf cam. I'm not knocking them because they do produce power. What amazes me is how a little Crane 104227 with pocket ported heads can bust off an 11.4x.
Old May 25, 2011 | 05:33 PM
trilkb's Avatar
think your confusing custom grinds for LE and AI's cams that they produce regularly. Some of them mentioned on their sites are grinds that they do for certain builds, a Custom Grind is something they grind specifically for you and what you want out of the car. Yes 20-30 people could be running the camshafts on their sites, but if you call in and order custom, unless one of those cams perfectly suits your application, they will grind you one for your needs.
This guy could benifit from this since he wants something that doesnt have crazy idle characteristics and can be used daily. Im not a cam wizard but im sure duration vs LSA has something to do with that, so perhaps a XXX XXX duration on a XXX LSA will give him both power and driveability. Since he has ported heads he could benifit from a higher duration camshaft but ground in a more street friendly manner.
Old May 26, 2011 | 03:37 PM
ok so i f i do run a 11.5 cr still no one has answer my question will th3 503 be a good cam n produce enough hp to make 400 or would have to get a bigger cam such as a cc306 somone plz help? the reason i ask is my buddy got both cams laying around and i got them next to nothing...
Old May 26, 2011 | 06:01 PM
trilkb's Avatar
depends alot on how well the heads are ported both of those cams like to rev up high to make power. If your heads are ported good your better off with the cc306.
