HP numbers with CC305?
Old Feb 24, 2004 | 08:29 PM
Chevy053's Avatar
Default HP numbers with CC305?
I think I have decided on the CC305 cam because everyone seems to think it has good low end torque which is good for every day driving. But what kind of of top end HP does it make because I want to make sure its noticably better than stock which seems to quit at the last couple RPM's. If anyone has a dyno sheet of the CC305 with stock heads that would be great too.
Old Mar 2, 2004 | 03:05 AM
Vendetta's Avatar
a 305 with bolt-ons and a full exhaust should dyno around 320-340 RWHP... it should pull to redline pretty good, as any aftermarket cam will. the 305 along with the hotcam are the most popular street cams for the LT1 for a reason... if you go 305, you will not be disappointed. however, don't go into it looking for a hard hitting rough idle cam, because that's not the 305's strength. however, if you choose it for a streetable daily driver, and you will be very happy with the results.
oh yeah, here's a dyno sheet from an OBDI LT1 with a 305 (w/ 1.6 roller rockers) and a full exhaust...
