VATS resistor bypass help inside please
Old May 27, 2011 | 02:55 PM
Z28Roxy's Avatar
Default VATS resistor bypass help inside please
I don't know much about electronics I need to bypass my VATS (at least for now). I tested the key and I have pellet #4 - 887 ohms.
I have some 887ohm resistors and having said that now how do I do it? Do I just solder one resistor leg to one white wire and the other to the other white wire?
http://shbox.com/1/vats_bypass.jpg
Old May 27, 2011 | 03:03 PM
shbox's Avatar
Just like the bottom diagram shows and what you said. One leg of resistor(s) to white, the other leg to purple going toward the VATS-not the column.
Old May 27, 2011 | 05:24 PM
Z28Roxy's Avatar
Thanks.
VATS = history! Now to figure out the other no start problem.
Old May 27, 2011 | 05:57 PM
TSAEB's Avatar
I taped up my resistor and just slid it in .....i had to make all the vat kesy since i lost my only key....hope this helps.
