Do I need this?
Old May 28, 2011 | 12:44 PM
Smoke Em's Avatar
Default Do I need this?
do i need the heat wrap that goes around the line to the brake booster?
its highlighted in the pic
Old May 28, 2011 | 01:06 PM
Gojira94's Avatar
If you don't like it starting to look ratty, you can redo it with some heat wrap from DEI. I used some of the sheet stuff, about $16.00 at Advance.
Old May 28, 2011 | 01:09 PM
henry172's Avatar
You could just remove it; there is not enough heat to hurt that line.
Old May 28, 2011 | 01:40 PM
shbox's Avatar
It protects the hose from heat from the exhaust manifold.
