I need lt1 help please
Old May 30, 2011 | 01:27 PM
GITSUM95Z's Avatar
Default I need lt1 help please
ok, i have a 383, stock heads & intake, comp cams 306. i have a Dynospark ignition with MSD cap, MSD 6al box.
ok here is my problem. i have the motor in and everything hooked up. i hit the key fuel pump comes alive, fuel pressure gauge reads 41 psi, fuel to the rail, turn key to start position and it (the motor) comes alive and immediately dies. then crank agian and motor turns over but hits every 3rd reveloution. let it sit for 20 mins and it does the same thing over agian hits and dies. i have all the ground wires hooked up. all power supplies are hooked up. pc harnesses are hooked correctly. with the key on im getting power to 1 side of injector plug. no pulse to injectors. the only wires i disconnected was the msd wires (factory harness spliced to msd 6al box to msd coil).. ok i cannot find the msd wiring diagram that shows me the "hillbilly" hookup to make sure its right. i did not buy the msd adapter wire i had just spliced them in.
the cam timing sprocket, and crank sprocket is dot to dot. facing each other.
i honestly dont know where to start. any help or suggestions are greatly appreciated
