Oil pan help
Old Jun 7, 2011 | 01:33 PM
lt1camaro383's Avatar
Default Oil pan help
I am in need of help about which oil pan to go with. I have a 97 camaro with 383 3.75 crank and 5.7 rods. I've been looking at this summit oil pan but didn't know if it would work with my car or not (hitting the cross member)? http://www.summitracing.com/parts/SUM-G3603/
Not trying to spend a ton of money on one but need the clearence for my stroker kit and advice or what you've used on ur 383's will be greatly appreciated.
Old Jun 7, 2011 | 01:50 PM
quik95lt1's Avatar
the 383 should clear the stock pan......but i used a canton 242t on mine just for the extra oil capacity....
Old Jun 7, 2011 | 01:57 PM
Put the stock oil pan on yesterday and #3 and #4 rod bolts are hitting the pan when i spun the engine over by hand.
Old Jun 7, 2011 | 02:00 PM
quik95lt1's Avatar
sometimes they clear......if you're using a bulky rod they can hit......the canton is a really nice piece........bit pricey but its worth it.......got trap door baffling, windage tray, crank scraper and a back baffle........nice pan
Old Jun 7, 2011 | 02:53 PM
RamAir95TA's Avatar
+1. Same pan I've got.
Old Jun 7, 2011 | 03:46 PM
With the built in windage tray will i still have to use my stock mindage tray as well?
Old Jun 7, 2011 | 03:52 PM
quik95lt1's Avatar
no........
