Hot Cam Dyno....
The custom grind was the better fit. The old 180cc comp port AFRs I have flow 276@.600. The 503 wasen't making full use of the cylinder heads.
Your elims should be in the 260ish range. The place that flowed mine had a set of 180 elims with them couple years back and they flowed 266/205.
Mine never dynoed "high" numbers but that really didn't bother me as much as what it ran on the street and track.
I didn't see anywhere that you had bigger injectors, were yours OK when on the dyno?
