shutter/shake issues<<<<<<Help>>>>>
Old Jun 12, 2011 | 08:58 PM
hotbird95's Avatar
Exclamation shutter/shake issues<<<<<<Help>>>>>
95 lt1, MAF cleaned and functional, ac delco 02's relatively new less than 1000 miles, brand new ac delco opti, brand new ICM, Coil wire, Plugs Wires New, double checked all plugs and wires to make sure nothing is burnt/chipped fouled, New Coil, long tubes, fuel pressure checked and within spec, TPS reading is within spec, tune by solomon. Under load (high gear/low speeds) at WOT, Fuel is getting dumped into the cylinders and makin it shutter and shake horribly. 02 readings are normal(data master). Fuel pressure is within spec. Any ideas? I'm at a loss.
Old Jun 13, 2011 | 12:52 AM
food nd cars's Avatar
Remember that spark plug wires don't have to appear burnt to be messed up.
Old Jun 13, 2011 | 07:32 AM
SS RRR's Avatar
Village Troll
How was fuel pressure checked? How do you know fuel is dumping into cylinders?
Old Jun 15, 2011 | 04:40 PM
hotbird95's Avatar
The issue is only happening while in closed loop...if it was spark plug wires wouldn't it happen all the time? Fuel pressure was checked with manual fuel pressure gauge and I know fuel is being dumped in by my tuner telling me so...
Old Jun 19, 2011 | 04:41 PM
hotbird95's Avatar
Come on guys I need some help! I'm at a total loss
Old Jun 19, 2011 | 04:59 PM
SS RRR's Avatar
Village Troll
How does your tuner know? Unplug the O2's, drive the car and see what happens.
