abs delete questions
Old Jun 19, 2011 | 08:23 PM
95batmobile's Avatar
Default abs delete questions
im doing a turbo build right now and we are going to delete the abs tommoro for to make room for piping.
there is a mess of wires connected to the module. is it gonna throw a code once i delete it? and if so is it just a fuse i can pull to get rid of the no trac or abs light? or can it be tuned out.
thanks
Old Jun 19, 2011 | 09:08 PM
RamAir95TA's Avatar
The ABS system is separate from the PCM and has its own set of codes. By FAR the easiest thing to do is to unplug the wiring, tuck it/cut it/etc. and just pull the bulb(s) in the dashboard.
Old Jun 19, 2011 | 09:24 PM
camar0corey's Avatar
I exposed the wiring about halfway back to the firewall and clipped it. Re-taped the plastic sheath.
Once I learned a completely stripped down wire harness is only worth about a 20 lbs. loss I quickly lost my motivation to get every last inch of unneeded wire out of the car.
Old Jun 20, 2011 | 05:33 AM
OOOooo ok thanks guys thats wayy easy
