Lower Shift Points = Lower ET's??
Old Jun 30, 2011 | 06:55 AM
T/ALT1's Avatar
Nobody can tell you what it will run, you can guess if youd like but that is all it would be. I have seen a few cars go quicker by lowering the shift point a couple hundred rpm but there is only one way to find out. You would also need to know the DA, etc.. to make a comparison or make one pass shifting regular then the next pass, lower the shift points to find out.
Old Jul 1, 2011 | 06:13 PM
trilkb's Avatar
Originally Posted by Mystery Bird
What do these questions have to do with my original question? Just curious?
I was just amazed your running a 1.55 60 and its still in one peice lol.
Old Jul 1, 2011 | 07:45 PM
Mystery Bird's Avatar
I know I'm pushing my luck huh?
Old Jul 11, 2011 | 09:43 AM
I finally made it to the track this past weekend and, well, too many variables came in to play to say. With the shortblock replacement, DA was over 2000 points higher than last time, and lower shift points , the best I could manage was an 11.85 @ 113.
Old Jul 11, 2011 | 10:20 AM
SS RRR's Avatar
Village Troll
It's really simple. Find out where your power peak is and have your shift points on your power peak and the result will be the best performance out of that setup until the power peak is changed.
