Need Clutch Help Please !!!!
Unbolting the slave and its aluminum housing will let you look inside to see whats going on, like pro94lt said, but you can't really see a whole lot without taking the transmission out completely.
If you decide to drop the tranny, which isn't as hard as it sounds, just make sure you've got good help or a tranny jack because our T56's are around 130lbs.
Gotta remove your center console and unbolt your shifter, drain your trans fluid, unbolt the torque arm and driveshaft, disengage the clutchfork, unplug the various solenoids on the drivers side of the tranny and reverse light switch on the passenger side. Then get a jack under the transmission and unbolt the crossmember and the 8 bolts that hold it to the bellhousing. The top two are sort of a pain to get to, might have to tip the tranny back a bit to reach them.
Then slide/wiggle the transmission back and out and you've got a clear shot at your throwout bearing and clutch. Good luck.
