no spark at coil, VATS?
Old Jul 10, 2011 | 06:43 PM
snkebait94's Avatar
Default no spark at coil, VATS?
Ok so after a cam and t56 swap my car wont start. It cranks, i can smell fuel after cranking, but there is no spark at the coil. I just replaced the opti, the harness, and the msd coil is about a year and a half old. After going under the dash to take out the steering column to install the slave cylinder, the white/black wire came out of this connection, http://shbox.com/1/vats_bypass.jpg. And the security light is on when the key is in the on position and when i try to start it. Would that be keeping my car from starting? Would i have to fix that connection before i can do a VATS bypass? Or can I just get it programmed out of my computer? any suggestions are greatly appreciated, thanks!
Old Jul 10, 2011 | 06:57 PM
bigj2717's Avatar
If it cranks it's not the VATS
Old Jul 10, 2011 | 07:03 PM
snkebait94's Avatar
could it be anything to do with the security light or is that all the VATS too
Old Jul 10, 2011 | 07:07 PM
bigj2717's Avatar
The security light is the VATS
