Went to the track, analyze my timeslip!
I see a "decent" timeslip giving the conditions....
That is quite a biut different from what I forsee should he put his money where it belonged in the first place, suspension. Had he hooked an had traction that would have been a good timeslip.
A stall is a must with that cam, the rear gear is OK but it will make your stall bigger, say a 200 or so difference. I would put a quality 3-3600k stall in there and you may be bottom 12's (with suspension) posssibly in great air 11's, but that is extremely hopeful with the stock top end.
The 847 with those cubes on a stock top end is making a boat load of torque, so I could see why it is getting so squirrely lol
The heads and intake ARE holding it back for sure, especially on the top end. I think that the car isn't breathing well at high rpms. Gears are definitely in the future as well. I need to talk to the PO as well just in case it DID have a different converter put in. As far as the 10 bolt and Drag radials, I'll probably get brave and throw a set of DR's on it next year, and expect the rear to fail. It will be a strange S60 or a Moser setup after that... along with PH bar, LCA's and a decent Torque arm relocated off the trans.
I thought it was pretty good for what it is... but maybe I'm wrong?
This was my very first outing in the car. The only things I did to the car after it was bought was an Optispark and the rear tires. Thats how it sits now. I bought the car in late April, and this was my first time at the track with it.
I still say she runs pretty good, just get the suspension and stall and you will feel like you got a new car. Over time you can decide whether you want heads.
However, it is clearly a HUGHLY miss matched set-up that folks are trying to help with.
I agree though, heads, intake, converter and some tires would really help a lot. Rear end gearing too. I'd be willing to bet those HUGE corvette wheels weigh quite a bit too.... unsprung weight is a killer. I'd be willing on dropping to a 17" if I could trade someone LOL
Those huge ZR1 wheels and dr's are terribly inconsistent also. 15" bias ply is the way for a manual
