What is this?
Old Jul 17, 2011 | 10:43 PM
food nd cars's Avatar
Default What is this?
What is this and where does it bolt up to? Its right next to the ICM. One of the vacuum lines go to the AIR pump "i think"
Old Jul 17, 2011 | 10:44 PM
Lawhead's Avatar
EVAP Solenoid ?
Old Jul 17, 2011 | 10:50 PM
no i think the evap solenoid is on the pass. side of the manifold. I hooked that up already.
Old Jul 17, 2011 | 11:03 PM
shbox's Avatar
http://shbox.com/1/air_pump_recall.jpg
Old Jul 17, 2011 | 11:08 PM
Originally Posted by shbox
I tried to mount it their earlier and it wouldnt fit.. Diagrams don't lie tho, Ill go try again.
Old Jul 17, 2011 | 11:40 PM
btw when i put some artic silver grease on the ICM and bolted everything back together it looked like it all got compressed and found its way out through the edges.. I'm sure some stayed behind but a good amount got squeezed out when i tightened the ICM back together..
Old Jul 18, 2011 | 09:27 AM
ZFreie's Avatar
Thats the idea with thermal paste, works the same with computer processors. All you want is a layer thick enough to transfer the heat correctly, way too much and too little are also bad. You really don't need much of the stuff, a good pee sized glob will usually suffice. Any pics of the icm and it squeezing out or did you already clean it up?
