no injector pulse please help
I should start a thread on how to troubleshoot an Opti. All one needs is a decent voltmeter and a logic probe. Easy test.
Al
My left lug bolt stripped and I changed the Opti and it's STILL stripped! WTF!!
Here is a diagram of the connector. Notice two wires should have pulses, PPL WHT and RED BLK.
You need something like this:
http://cgi.ebay.com/DTL-TTL-Cmos-Log...item3cb9f802e1
It will in a second tell you if the pulses are there are not. A better tool would be a lab scope, but if the pulses are there they most likely are correct. Did you check for trouble codes in the PCM?
Al 95 Z28
