Mallory 685 help please
Old Jul 30, 2011 | 10:12 AM
lncboytre_d's Avatar
Default Mallory 685 help please
I hook the box up today using the MSD adapter harness, I am 99.7% sure that the box is installed correctly, yet the car won't start. I disconnect the box and she fires right up. I reconnect the box....nothing. I leave the box connected and use the bypass harness and she fires up. The start retard is set at .01, I have played with it all the way up to 10* of start retard. What am I missing?
Old Jul 30, 2011 | 11:07 AM
gregrob's Avatar
Its either wired wrong, you have a power source supplying the box that gets interrupted when cranking, or the box is bad.
Old Jul 30, 2011 | 12:12 PM
I ran the constant source staight to the battery, I'll go back over the wiring.... How can I test to see if the box it self is bad?
Old Jul 30, 2011 | 12:23 PM
gregrob's Avatar
Don't know of a way, other than the car not starting
How did you cross over the wires between the Mallory colors, and MSD harness?
Old Jul 30, 2011 | 01:34 PM
mallory msd
red...........red
black.......black
green .....white
yellow......orange
Maybe the box is bad. Wouldn't be the first time I received a bad ignition part....opti, icm, coil, 1 bad msd plug wire in a set....
